rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 2,334 Reaction score 213 Location WIRRAL Dec 22, 2016 #1 hi all I have an optimate charger and the fuse has gone in the connector lead that stays attached to the battery, what amp fuse is it .
ghost-rider Registered user Joined Nov 13, 2012 Messages 1,166 Reaction score 0 Location Birmingham Dec 22, 2016 #2 hav a look and see for yourself
Bryn Moderator Mod Squad Moderator Joined Sep 20, 2003 Messages 13,805 Reaction score 83 Location South Leicestershire Dec 22, 2016 #3 2 amp should do it
rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 2,334 Reaction score 213 Location WIRRAL Dec 22, 2016 #4 no indication on the fuse itself 2 amp seems very low
bigtwin Active member UKGSer Subscriber Joined Feb 25, 2012 Messages 329 Reaction score 7 Location Derby Dec 22, 2016 #5 Typical charging currents are usually about 10% of battery capacity so 2A seems about right. What's the worst that can happen?
rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 2,334 Reaction score 213 Location WIRRAL Dec 22, 2016 #6 rang optimate they bloke says up to 5 it's 7.5 amp after that 15 amp
JJH Well-known member UKGSer Subscriber Joined Jan 17, 2009 Messages 9,696 Reaction score 203 Location Co. Meath Irish Rep. Dec 22, 2016 #7 And the one after that is 20 amp. What's up till 5? Is that pm? I would say 2 amp but no more than 5 under any circumstances. JJH
DC Registered user Joined Mar 29, 2014 Messages 4,156 Reaction score 13 Dec 22, 2016 #8 is it a blade type fuse ? they are coloured coded http://www.healey6.com/Technical/Fuses.pdf
Rugged Path The Honourable. UKGSer Subscriber Joined Jul 23, 2004 Messages 2,184 Reaction score 56 Location Wybunbury, Cheshire East, England, EU Dec 22, 2016 #9 7.5amp is what they normally come with. Sent from my iPad using Tapatalk
Chicken Active member UKGSer Subscriber Joined Oct 21, 2015 Messages 384 Reaction score 2 Location Cambridge Dec 22, 2016 #10 Mine was supplied with 15 Amp
wessie Registered user Joined Jan 8, 2002 Messages 13,148 Reaction score 485 Location Welshpool Dec 22, 2016 #11 http://accumate.co.uk/OptiMate 4 CanBus Edition Instructions.pdf 15A - see "BATTERY CONNECTIONS" section
rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 2,334 Reaction score 213 Location WIRRAL Dec 23, 2016 #12 Up to optimate series 5 Sent from my SM-G357FZ using Tapatalk
rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 2,334 Reaction score 213 Location WIRRAL Dec 29, 2016 #13 went out to connect the charger up and the 10 amp fuse had blown , nothing has been connected to the lead ,bike has not been used . very puzzling
DC Registered user Joined Mar 29, 2014 Messages 4,156 Reaction score 13 Dec 29, 2016 #14 rover .do you have a lot of accessories on the bike ? just thinking you might be overloading the can bus system and this is causing the blows when you plug something extra in
rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 2,334 Reaction score 213 Location WIRRAL Dec 29, 2016 #15 no just what the bike came with its a 2011 gsa with the usual aux lights grips etc . the charger leads are straight to the battery .
MikeO Well-known member UKGSer Subscriber Joined May 31, 2002 Messages 12,152 Reaction score 201 Location Dereham, Norfolk, today... Dec 29, 2016 #16 rovert57 said: no just what the bike came with its a 2011 gsa with the usual aux lights grips etc . the charger leads are straight to the battery . Click to expand... Have you pinched the cable? Easily done in a small workspace...
rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 2,334 Reaction score 213 Location WIRRAL Dec 29, 2016 #17 Wad thinking that but cannot see any damage Sent from my SM-G357FZ using Tapatalk
