Deleted account 191119001
- Joined
- Aug 13, 2017
- Messages
- 12,799
- Reaction score
- 5
Nice one and remember just use a small torque wrench, and no more than 9nm, when it clicks thats it ...............
Straight splined extractors work well in skilled hands, its all about experience & patience!
I sometimes wonder about all this torque stuff. I run a 1200 GS, a Street Triple R 765 plus a 1967 Triumph TR6. I work on the TR6 all the time but never use a torque wrench. A ring spanner at best and you just know when it’s tight enough. Never a problem.
Same with the GS but the Street triple is still new.
A pal of mine works at a large Motorrad dealer, and whenever he came to the house to work on my bikes NEVER used a torque wrench. He said you know when the bolt is tight
Not using torque wrench on bolts that screws into aluminum is stupid. While overtight a bolt in steel or cast iron does not do much harm, aluminum accumulates loads, and if you overtight only once, the damage has been done in the sense that there is a great chance of the threads being stripped later on.
This "feeling" some people brag about is bullocks.
Especially when you have some bolts on bikes like the S1000R are 3NM and 90 degree turn one use only bolts.
what.. stretch bolts!.. where are these used other than the cylinder head? madness!!
Aluminum expands a lot more than steel/iron, so stretch bolts are handy to use in areas exposed to variable temperatures, such as the crankcase, brake disks and cylinder-heads.
If none stretch bolts are to be used in these areas they would require longer screws with higher torque and heavier material surrounding the treads in order to handle the expansion during variable temperatures. Thus, in my opinion, I would not use the word madness
Bolts like the on the clutch and stator cover on the S1000R are stretch bolts.
Why?... how did my CB1100RC and Z900 ever stay together in the old days
Ive seen the result of stretch bolts in V8 blocks... pulled up localy and even pulled out in some instances.
We've replaced these with studs most times and had no issues at all. I can't see why you'd need them in 10mm or ali on a brake?... again, many car / bike applications use ali calipers and standard bolts.. dab of blue and its sound.
