Roger P
Introducing Caribou Motorcycle Luggage Systems for BMW GS's, Suzuki V-Stroms and Kawasaki KLR. Based on the Pelican 1550 case, this is the world’s toughest, most waterproof, and most durable luggage system…
Weatherproof NEMA 4 rated key lock integrated into the Pelican case, so you don't need padlocks to lock the lid shut. The weatherproof compression lock (big knob in photo below) secures the case to the bike and is keyed to match the case lock.....
The external Quick Release compression lock system allows the cases to be taken off and on the bike in seconds, no need to open the case to access pucks or latches.....
Dual lid lanyards take the stress off the case lids and keep the lid from opening past 80 degrees creating a convenient shelf. Elastic straps with a clip in the center hold your gear into the large cavity of the case. These features keeps your gear from falling out onto the ground...
Optional Inner bags designed specifically for the Caribou cases are available to keep your gear organized. Take your gear from the bike to your hotel room in style...
Pelican/Caribou case material is extremely tough, durable, shock absorbing, and water tight. It won't shatter or crack like hard plastic, won't dent and bend like aluminum, it is by far the toughest motorcycle luggage in the world...
Strong 3/4" 16 ga TIG welded steel tubing is used for the rack/rail system, designed for a clean uncluttered look. Heat resistant Teflon-like bushings at all contact points prevent metal-on-metal wear and fatigue. These rails are basically an extremely strong exoskeleton frame on your bike and act as crash bars when the cases are off....
A rear cross bar tucked under the fender creates a strong box structure. The lower rear corners are tucked-in toward the wheel to minimize snags on rocks, stumps and trees....
Plenty of room for passenger’s foot on passenger peg...
Narrow profile, only 35" to 38.5” width (depending on bike) across outside of cases at widest point. The cases are up high enough for canyon carving, but you can easily swing your leg over the top.....
All bracket/rail parts are made of steel, so they are field repairable in the event of a very bad crash (no exotic alloys or aluminum). The compression lock cam lob is designed to break-off in the event of a hard crash so the case can eject in order to protect the bike's subframe. A "limp home" feature allows you to temporarily strap the case to the rail in the event of a hard crash. A new compression lock is only $25 USD.
The Pelican cases and the rack system are offered as a complete set or as seperate items. The Pelican case used here is the 1550 (35 liters per case). The quick release rear top case (coming soon) will use the 1550 and 1520 (25 liters per case) as well. For the BMW 1200 & 1150 GS, V-strom 650 & KLR there is enough room on the non-exhaust side between the rear wheel and inside of the case for a small tool kit case piggy-back to the 1550. This is an option called the "Toolkit Case."
This is the toughest most waterproof and durable motorcycle luggage system in the world. We ship worldwide via United States Postal Service Express Air (5 days to UK). For more information you can send me an email at info@adventure-motorcycle.com.
Here are a few additional photos....enjoy....
