stephen.stallebrass
In addition to the big end going on my F800GS, effectively ending my ride around Europe on the first fecking day, the second bane of the trip was the shitty side stand. I've lost count how many times it nearly went over when not on perfectly level ground. At least twice it nearly went over when lots of people were around and the excessive lean meant I couldn't use the pegs to get off, meaning I had to inelegantly shimmy off hopping to the side dragging my leg with me. And nearly taking the bike with me.
I have a Camel Toe thingy on the end, which is great at stopping sinkage but you have to lean the bike a little more just to get the damn stand down - doable but not easy when the ground is uneven and bike fully loaded. I use the the pegs to get off when I can but when on a slight camber this is impossible unless I recce a parking spot to ensure that it doesn't topple over. Is there an aftermarket side stand that solves this problem?
Will check the bolts when I get it home and definitely load up the right case with heavier items to counter the weight when on the side stand!
