cristhemuso
Suspension on max....?
I am surprised you have preload at max.
I am 5ft 11 tall an 11 1/2 stone. I ride my bike with rear preload at minimum and it is perfect. The rebound damping is best (on my bike) at a quarter turn out ie less than standard.
My gs is April 2009 and I had steering head bearings replaced a month ago. I had notch in centre position. Not too bad but I had noticed the bike fell into corners at low speeds meaning you had to counter steer round corners.
New bearings mean steering is 100% neutral ie no force on bars required round corners at any speed. I was pleasantly surprised and I realise my bearings must have been trashed from new since I had always had oversteer ie the bike falls into corners!
With so much pre-load your rear will be topping out and causing horrible wobbles and twitches and a loss of confidence that you are going to get round corners. If you have the rebound damping wound up to compensate then the bike will squat over bumps and round corners.
Try setting suspension to standard preload and damping.
Basically a common mistake is too much pre-load and extra damping to control the topping out twitches will give you diabiolical handling and a zero confidence feeling round corners.
With damping only dial in just enough to prevent any oscillations and no more. Back it off first and dial in a little if needed. Like I say my bike on standard damping handles best with a smidge less than standard for me.
Just my 2 pworth.
My original bearings were loose and BMW adjusted them ha ha. I insisted once they are loose they are shagged and sure enough they had to replace them a month later.
Also check Tourances are approved for GS800. With tubes in you should really only fit tube tyres since tubeless will have thicker stiffer side walls.
I ended fitting OEM BA's after talking through with BMW uk technical.
(please please no mention of dampening in any replies....)
Just my 2 pworth.
of bike
, i don't think they will quibble at £88 fault finding mission for the sake of you being a happy customer....write them a letter
with everything you've mentioned
