06 1200gs headlight warning lamp
Ken B
Member
Basingstoke, England
Hoping one of the experts can help. Headlight warning light came on at the weekend, it is the low beam not working. Changed bulb although old one looked ok and still warning light and bulb not working.
Before I start tracing the wiring etc are there any known faults that might do this?
Ken
Does highbeam bulb work?
If yes, swop bulbs over and try again.
After that don't know, I would have to explore wiring and connectors.
Or disconnect battery, reconnect battery and try all again.
Ken
Tell us you have started the engine, after changing the bulb....please.
Hi Wapping,
Thanks, started engine and hey presto.:beerjug: really didn't know that.
Ken
You are welcome. :thumb
PS When you drop the little nut on the inside of the windscreen (as you inevitably will) it will rattle about and then.........silence.
You will spend hours looking for it......
.......you will find it nestled at the bottom back end of the wishbone.....
Thank me now, or later....
