matt1 Guest Nov 20, 2007 #1 hi,does anyone know if the stanchions from a 96 1100 fit the lowers from an 1150,my 1100 ones are looking decidedly manky and i like the look of the 1150 ones better.
Colban Registered user Joined Jul 28, 2006 Messages 2,872 Reaction score 1 Location Lincoln. Nov 20, 2007 #2 The 1100 ones are 24mm longer and a different part number. I wouldn't like to mix and match. Check out parts here. http://www.maxbmwmotorcycles.com/fiche/fiche.asp
Nin Well-known member UKGSer Subscriber Joined Feb 23, 2006 Messages 5,395 Reaction score 593 Location Abingdon, Oxfordshire Nov 20, 2007 #3 Colban said: The 1100 ones are 24mm longer and a different part number. I wouldn't like to mix and match. Check out parts here. http://www.maxbmwmotorcycles.com/fiche/fiche.asp Click to expand... And greater dia too I fink? Tarka (remember him?) swapped the whole (uppers and lowers) lot from an 1150 to an 1100.
matt1 Guest Dec 4, 2007 #4 in case anyone else fancies the better looking front end the stanchions fit straight into the lower legs,the fork height remains the same as 1100... the only slight hiccup is there is nowhere to mount the brakeline splitter,need longer left hand line and then mount the splitter on the "fork brace".
Henry Mawson Registered user Joined Jan 3, 2002 Messages 673 Reaction score 0 Location Ready to be heading East Dec 5, 2007 #5 I have a set of 1100 Legs and stantions for £100 plus postage. Henry
