Hi,
I just fitted a new standard rear light lens to my 1100 and it seems to be quite loose on the mount, I would expect a certain amount of movement to absorb the vibration, but I'm not sure if there's too much and it's going to suddenly fall off.
Unfortunately, I didn't think to check the old one before I removed it, but the new one moves enough to be able to reposition it about 1mm (left/right, up/down) in the horizontal and vertical plane.
i would be much obliged if someone could check theirs and tell me if this is normal.
Thanks a lot.
David
Thanks a lot.
David
