1100 running rough.
  • Thread starter Thread starter FBF
FBF
ive noticed that my GS is idiling badly sometimes fast sometimes very slow. it will often cut out and it seems to be more often when its warm. any tips where to look?
Dan
oddly enough i was just telling someone that it felt like a vacuum leak.. whats an inlet stub? can you direct me to the right area? and will a tube used like a stethoscope hear the leak like i would do with a car?
thanks CM thats really handy 14 on this pic right?
It may need the TBs balancing or the CO2 setting (need a CO2 meter for that though.
If you do the general service yourself it will not cost you much to get bikes valves cleared, co2 adjusted along with idle speed etc by bmw. The gaskets that lead from the front of the throttle bodies to to cylinder perish and are worth checking. About @20 from Motorworks...
Lamba sensor?
