Hi,
I am new here so hello and thank you in advance for any advice, suggestions and help.
Only had the bike a month and the only ride on it was home after buying, thought it might be a good idea to check the brake fluid in the front to find that it was almost empty and the master cylinder piston was leaking. Fixed the piston with the repair kit and put on some stainless hoses whilst it was apart, all went well.
My problem is that when I turn the ignition on the top abs light comes on and stays on, no flashing, I have tried resetting the system to no avail. Have I done something or has anyone encountered this before, I was very careful when removing front wheel, mudgard etc.
When I rode it home the lights were working as they should.
One other question is it safe to ride with this light on.
Mark
Mark
