Possu
Yesterday I test rode an accident damaged 1994 1100GS. Back end was clipped by a car, sending it sliding down the road on it's l/h side. All this was not at high speed, maybe 40-50mph max.
The clocks, screen & headlight are smashed - possibly due to sliding into a kerb? L/h pillion peg snapped off also. The front subframe that supports the oil cooler is also a little out of shape on the l/h side & the plastic tank is scraped.
The bike rides well in a straight line & also turns well. The only problem I can feel is a "twisting" feeling from the front wheel, it seems to want to pull to the left? There appears to be no damage to the Telelever A arm - no dents, creases or even cracked paint. The forks are undamaged & the suspension works as well as you'd expect a 10 year old shock to work.
Tyre pressure seems okay without actually measuring it. Tyres are Tourances with plenty of tread.
Any ideas?
The accident happened a while ago, bikes been sat outside doing nothing. All I can think is that as the problem only manifests itself under braking is that one caliper is partially seized, causing the bike to pull to one side?
I'm tempted to buy the bike as it's for sale at what is IMO a very good price & deal with any problems if & when they arise. It also comes with a pair of system panniers & keys that were not on the bike at the time of the accident.
Thanks in advance.
Steve
Any ideas?
Thanks in advance.
Steve
