1100GS Front shock
donkeydoo
south east
Getting the old girl back after a few years lay up. Just sorted front brakes and noticed this lump of red rubber sitting on the telelever, look up and it seems the front shock has disintegrated, oh well.
As its not used a great deal what do you guys use as a cheapish replacement?
There is a fella on here that fixes these DenzO I think from memory .
Alas the front shock cannot be refurbished.
When I reached out to TTech Suspension (DenzO) I was advised that “YSS shock is the cheapest option under £400” from them.
I think @Wrigsby1 uses a YSS on his 1100 and is happy with it.
You could buy another BMW front shock used from eBay but I suspect they will all be near/at end of useful life at this stage.
The YSS is fine and my experience of front shocks on oilheads is set up up and forget... Mor many folk more complicated shocks will end up tying them in knots with their much wider adjustability....
Yep reached out to Ttech today and alas it is correct that they dont service the front.
So plumped for a cheap one from an 1150GS ,which from what I read will fit, from Sherlocks to get her going again if it lasts a year that will be fine....
The shock arrived but didnt have the rubber bumper stop, so effectively the same as what i had. Am guessing too that they all perish after 20 plus years.
Front is easy to get the spring off, you can then use any type of similar sized rubber bump stop from bikes cars etc . I always used old rubber bullets / baton rounds from work
