Namastebuzz
OK, I've given my 1100GS to Cyprys on long term lone but it's turning into a white elephant.
Had to change the clutch and then front brake master cylinder. THought it was all good and also balanced the throttle bodies using a DIY manometer (which I've done several times before).
When Cyprys picked it up to ride back to Edinburgh it died slightly at higher speeds and now it's cutting out and backfiring.
He's got new plugs for it and I advised checking ignition wires, sidestand cutout and fuel tank breathers although diagnosing at a distance is hard. The throttle cables ARE properly seated.
The backfire would indicate too much fuel in the mix I suppose? Would the balancing have cocked things up because it ran passably before? Anyway, I can't really answer questions on how it's riding but I'm sure if anyone has any ideas Cyprys will be along to illuminate things.
but believe they can break down gradually as it's wiring begins to fail.
