ren
Hi all,
Beacuse I have no 220V plug in the garage I just bougth a small solar charger to help the battery to live (abs well known issue). It appears to work fine but when connected to the accessories plug if I check the voltage in the battery terminals I see that it only delivers 4v. Question: Anybody knows if there is any voltage limiter between the plug and the battery terminals??
Note: If I check the solar panel voltage in the bmw 'lighter' plug before connect it to the byke it gives very good 17V...
Does anybody tried these solar gadgets before???
Thanks in advance
Renato
Thanks in advance
Renato
