paddy dougan
Greetings all,
I seem to have a charging problem with my GS,
fitted a new battery and charged it overnight but after running for a while and trying to restart, the battery is very low on juice. If I use the heated grips it happens even quicker. I have checked the tension on the alternator belt and it seems to be quite tight, quarter turn at longest point. The battery light goes off as soon as I start the engine, connections to the batttery seem fine. I did have to resolder the neg/earth terminal lead to the battery when I first had the bike but I think it's a good connection.
Anyone got any idea of how much voltage it should be putting out under load when idle and say 4k rpm?
Any help greatly recieved as I can't use the bike with it being unreliable,
cheers in advance.
Paddy
cheers in advance.
Paddy
