1150 GS rear shock bottom eyelet bushing
brewking
London
Hope some body can help with this possible simple question, is it easy to push out the bottom eyelet on the OEM rear shock. I bought a second hand shock which turned out to be for an 1150 RT and the bottom eyelet is just a bit too wide to fit into the swingarm space.
Bit of a mare, a local garage with a press will make short work of it or a vice
+1, it works this way. I changed the bushings in the reaction link under the shaft housing on my RT and did it also using a vice and lube to get them more easily inside.
Dan.
