- Joined
- Jan 3, 2002
- Messages
- 1,487
- Reaction score
- 8
Having just remounted my rebuilt Wilbers shock on the PD Classic I noted just how bloody tight a fit the bottom mount is - common to all?
I think on my 1989 R100GS I spent some quality time with emery paper reworking the mount to ease the fit.... there is no way you'd get the shock off at side of some godforsaken road in crisis. The shock will have to come off at some point so I'll need to 'modify' the mount. I'll have to make sort of a puller just to get the ****er off again I suspect
I guess a tight fit helps keep things tight, but as there is a rotational bearing at that end why so tight?
Anyone else found the same? Discuss
nowt.
on bottom mount after the 'cold spray'...hopefully it won't shatter
