Does he know?
He's got the small three pin diagnostic connector under the seat.
Does he know?
So that's not a 1100 to 1150 change then? The underseat plug that is.
lncmgl
Did you get your abs sorted?
My 2000 1150 has also started failing, 2 ABS lights flashing alternately.
It only started to do this a few days after changing the back brake pads, I'm wondering if this has anything to do with it?
I can do the reset by grounding the wire in the plug above the airbox, and then get the lights to flash together, however when I ride the bike away just after startup, and get the "kerklunk" sound as normal, the lights flash alternately again and I have no ABS.
I can reset it but its the same story over again...
Just wondering if you got yours sorted and if it was just the battery.
Well as he just said he's got an 1150 with the small underseat plug I guess not
From what I understand the early 1150's (up to 2002-ish) got the 1100 ABS2 with the small diagnostic plug and the two ABS lights. From 02 they got servo ABS with the big round diagnostic plug on the airbox and 'ABS' and 'Gen' lights. .
If you have an ABS fault wouldn't your ABS light stay on.... just for my own peace of mind as I'mall worried now that my abs doesn't work... as I have never heard a clunk. I have an 04 GSA with Servo... and I can brake so I'm guessing everything is fine... even if there is no clunk!?
Thanks Steptoe - my mistake - I went off what the OP said in his earlier post.All 1150 models have the round diagnostic plug regardless of servo or not.
Thanks steptoe! I also managed to conduct my own highly scientific test... I belted it down the drive way then hit the brakes hard. I get skid marks for about a foot... then nothing for a foot.. then skid marks for a foot... etc. Looks like they work!![]()
I didn't know that abs operation was part of the mot test.
I didn't think it was ? - I've never had the abs tested on any bikes.
Didn't bother me but I don't know how you'd get on if you'd done an 'abs removal' as the dvla computer would still report it as an abs bike?...as the dvla computer would still report it as an abs bike?...
