ABS Pro Failure
garethstew
Scotland
Hi guys, looking for some help. I've been to BMW twice now, and the first fix was a new battery that cleared the ABS pro failure code for about 2 weeks, and then it's came back. So took it back to BMW again this morning, they could not find anything wrong, cleared the codes and called it good. Got home and error back again. They say might have something to do with me flashing the TFT to have sport mode and changing the theme, but I don't think it's that. When this error comes up, I can not clear it, cut the indicators off so can't use them or any button for that matter. Has any had this issue, looking for a better fix than just clear the error with gs911.
It would help to know the error code as to what it (the EML) is saying the issue is/where it comes from.
I have the TFT set to sport mode, have had for a while now. No such issues here. When you say "flash" do you mean through GS-911? You can always go back to standard and try that. See what happens.
Yeah, I changed the stuff through the GS911. I think I might have found the problem. Got home, started looking around under the seat, and found a blown fuse. Don't know if that's enough to upset the bike, but the ABS pro alert gone off the TFT, so we will see if that was the issue.GS911 not showing any error codes now all gone back to green on the check
