petea
hi i have just fitted hid lights to my 1150gs 2001
when i went out to test the lights i noticed the dip beam is flat on the left
but rises up on the right as cars came towards me you could see the car light up as i passed no one flashed me but it didnt look right.i looked in the riders manual and haynes manual and they both described a instant adjustment for right hand driving and left hand driving i carried out the instructions but the headlamp would not turn as described so i took the whole light out and found there was an additional clamp screw at the bottom of the headlight and also on the left hand side there was a pin on the headlight plate and three holes on the clamp plate the pin was in the centre hole so i loosened everything off and turned the headlamp till the pin was located in one of the other holes.put headlamp back on bike when you look at headlamp the filters on the lens are now at a angle rather than being flat the beam pattern looks better in the garage it is now flat on right and rises on left which looks right to me not had a chance to try a test ride yet.anybody know if this is a correct adjustment procedure or am i missing something.
but as described when i tried to carry out the adjustment the headlamp wouldnt turn.has anyone who has fitted hid lamps needed to carry out this adjustment? to obtain the correct beam pattern.i will check with the company i bought the lamps off to see if they have any advice.
