Boxergs
Hi Folks,
Recently got my 1150gs back from repairer's after an off on Oct last year. She had a bit of a bash to the nearside and a nice slide down the road on its nearside.
Repairs done via insurer's, pleased with the work but haven't been able to ride her to make sure she run's fine due to injuries until today
Only to find that at around 4k rpm (but not always) she seems to choke and die, possibly fuel starvation. Now I've put some new fuel in, tested, same. Undid fuel filler cap and tested again, still same.
She is also quite rattly, seems nosier than before and sounds like tensioner maybe? Now thats on the offside but could it have been damaged after the original impact and slide and then lying still in gear and running on its side with oil pouring out from a hole in the rocker cover on the nearside?
The repairers reckon they road tested it but I reckon that was just around the yard or block and didn't get the revs up much.
Now before I start to pull off the tank to check for any nipped hoses etc, is there 'owt else I should be looking at? I thought maybe cracked throttle body (from the crash) but surely it would just run badly all the time?
If it's not relatively easily fixed I'll be sending it back and they can sort it but I reckon they'll try and wriggle
Any advice appreciated
