1150GS ADV Does not Start
  • Thread starter Thread starter ricochet
ricochet
I have not used my Adventure for 2 mos. due to rains. I tried to start the engine today to no avail. Exactly last week though, it started in just one press of the starter button. I am puzzled why. Any ideas?
you may need to add some more detail to your post.
does it turn over?
do the lights go dim, when you try to start it?
any clicking sounds?
none of that happens. In fact battery is hooked to a battery tender 24/7.
Presumably you do get lights on the dash when the ignition's on????
:confused:
Did anyone notice where he is, when it rains there its serious.
More detail needed Ricochet
It'll be under water then. You could try fitting a snorkel ;)
Alternatively, asside from the usual culprits (fuel, battery, kill switch, not in neutral), the troubleshooting chart in my GS12A handbook has this entry:
Possible cause:
Clutch pulled when ignition was OFF
Remedy:
Switch on the ignition, then pull the clutch lever
Not sure what that's all about, but you could try it.
HTH, Derek.
