1150GS complete spotlight kits
I could be quite interested in one of these. Does anyone have any photos they can attach to show the installation - where they mount the switch etc.
Berwick
the on/off switch supplied is the PIAA waterproof switch
http://www.nippynormans.com/prodinfo.asp?number=PIA-74034&variation=&aitem=2&mitem=7
it is usually mounted on the left side of the instrument binnacle using the self adhesive pad supplied... its just looking for a clean flat surface to adhere too
the spotlight bar just mounts up under the oil cooler using the two longer screws and spacers supplied
1150 kits are available
1100 kits all sold till Jan 8th
how much
great, and presumably, they are fine to be run "on" all of the time with dips?
yep
the ring lamps use a standard Halogen H3 55watt bulb (per) so a blown bulb wont break the bank, the lamps take their power direct from the battery through a relay and fuse (all pre-wired)
how much
Can't pm (why??) so here goes:
Already have a nice set of PIAA's but still looking for a light bar...will you sell it separately? (and how much would shipping to Holland be?)
You can reply to wimvdluijt @ gmail . com (just leave out the spaces)
OOPS...forgot...have a 1150 GSA
Thanks!
thanks
you need to subscribe to the site to the site to use the "pm" private message. yes i supply the light bar with fittings
will email you when i have postage cost:thumb
Thanks!
no more 1150 kits available till mid January.... sorry!
thanks to the 4 guys that have bought them this weekend:thumb
please pm me to check next availability if you would like to reserve a kit from the next batch
thanks
How much
I'm in a bit of a hurry to get my lights sorted...So I think i'll have to pass on your offer..sorry
really sorry i ran out of lightbars and kits over the holidays.... demand was unexpected and really caught me out.... that wont happen again:thumb
the next batch of bars are off to the powder coaters in the morning so bars and kits will be available for posting from early mid next week
3 full kits have already been reserved from the next batch:thumb
just pm me with your requirements
payment can be made via paypal or cheque
thanks
How much
DID THIS MYSELF A WHILE BACK,BUT FIND THEY BLIND ONCOMMING TRAFFIC,IS IT POSSIBLE TO PUT A SMALLER BULB IN AND IF SO WHICH TYPE, HAVE THEM WIRED INTO THE DIP BEAM WHICH IS HID SO NOT REALLY NEEDED BUT GREAT FOR WATCHIN THE CARS PULL IN AND LET YOU BY.
Fitted my light bar this afternoon, and I'm very VERY impressed....... A quality piece of kit and a doddle to fit... ( I mean if I can fit one, anyone can..... seriously, is not difficult).
Trying to post pics but I'm having a few probs.....:mad:
Berwick
I have to admit I wasn't happy about putting the switch as described above.. so I put mine here.
So far it's remained absolutely solid.. held in place both by the adhesive pad and a tie-wrap as shown.
If it comes loose my intention is to get a jubilee clip - have a small flat plate either welded or riveted in place and stick it to that in the same position.
but so far.. it's been fine.
motobike
your switch position looks good... bit more user friendly where you have it:thumb
note: the switch is "push" on and "push" off with quite a light action so is ideal for a gloved thumb.. the switch LED iluminates red or green to indicate on/off
its a quality item and worth the extra expense!
PJAY blinding other road users isn't really an issue, the lamps i supply are adjustable up & down and side to side :nenau bulbs are H3 55W Halogen
how much
This is true... I have after a bit of experimenting got mine in a position where they 'fill out' and hugely improve the 'dip' and when on High beam they continue to illuminate the 'dip' area - which all in all is a massive improvement for both light positions.
With the spots in a permanent 'dip' position I have yet to be flashed at by an Irate (temporarily blinded) cager. :thumb
What about making a batch for the 1200? Sure you will find many takers! :oonyack
Big Tom
watch this space! I AM working on them at the minute, the firstbatch of 1200 light bars should be going to the powder coaters by this weekend:thumb
How much
