John Leah
My 2002 1150GS had been sat unused since August but with BMAD this weekend and weather improving I thought I'd better get it back on the road so booked an MOT for this afternoon.
This morning I parked it on the lawn and gave it a good clean and checked it over. Problem... rear brake light not working - bulb OK as front brake lights it so suspect the switch. Removed it, cleaned it but still no joy so ordered a new one from Motoworks.
Got to the MOT and, not surprisingly it was spotted but the nice mechanic accepted that as I had a new switch on order it would waste everybody's time to fail it on that. Good man!
Then he spotted the side lights weren't working! Bulbs OK, fuse OK so suspected the handlebar switch but a spray with contact cleaner didn't make any difference so he had to fail it after all.
Got home and removed the handlebar switch cluster to get better access to the contacts yet a liberal spraying direct into the back of the switch made no difference. This stumped me so I suppose next step is to trace the wiring but as my DVM is broken I can't do that today.
Also, which may be related, is that the ABS lights flash alternately - did I read somewhere that side light failures can upset the ABS diagnostics? I have had occasional ABS flashing problems but always put this down to low battery voltage as stopping and restarting after having ridden for a few miles always cures it. Note: Brake fluid changed year before last and about 3,500 miles ago so intended to change again this year.
Dodgy switches are perhaps hardly surprising as about the only use I had of the bike last year was to tour Ireland... in the pouring rain!
So, can anyone suggest why any of this may be and could any of these issues be linked?
Cheers,
John
Cheers,
John
