steele01
Hi everyone hope we are all well just wondering if I can pick the brains on the collective knowledge base off ukgser.
I'm currently in the process of returning my 2004 1150GSA Back to stock.
The bike when I had it had the following k&n, Y Piece which was running with the o2 senor in place, and some sort of straight through can with double exits n the bottom one blocked off Running straight through on the top one.
It's got some print out's from Hilltop back in 2010 of dyno pulls when I assume the exhaust was fitted.
Bike ran great,
I've just refitted a stock exhaust silencer, cat o2 sensor, and am waiting to pick a stock air filter up when it get's in at the dealers. Not fired her up t
Now bearing in mind although I'm 34 I'm more familiar with whitworth spanners, Norton's an jets + plug chops lol
What's the crack with the ECU's on the 1150, where should I be looking to see what's been done would it be a chip in the motronic ecu? or software.
I had a look to see if there's an coding plugs under the seat, an it's got none installed.
Has anyone done anything similar removing a system, and going back to a stock setup is the ECU sophisticated enough to adapt back to the stock exhaust? With whatever hilltop would have done back in the day?
Just wondering how others would approach it, I have loaded maps on a 675 Daytona in the past but I had the Triumph software at the time.
Any advice would be greatly appreciated
Many Thanks
Bike ran great,
Many Thanks
