1200 gsa headstock plug
Pauly S
Near Sevenoaks,Kent
Anybody know the operating parameters for the sat nav plug on the headstock? Amps capability and when does it come on and when does it turn off? i was thinking of using it for a pair of 10w led drls TIA.
The sat nav plug goes off after about 30 seconds as it is canbus controlled.
If I was going to use it to power anything other than a sat nav I would use it to trigger a relay and use a fused feed from the battery through the relay to the device.
thanks for that. top man.
5 Amps is about 50 watts (allowing some leeway) so a pair of low power daylight LEDs will be no problem.
But the can bus stays on for quite a while after ignition off so you are probably better tapping into the rear power outlet or tail light and using a relay.
The relay won’t confuse the canbus bulb fault circuits and allows other stuff to be connected when the time comes.
5A so should be loads for what you want it for
thanks for that, top stuff
