I heated the housing and chilled the gear spindle (put in plastic bag) and chuck in the freezer for an hour). The parts dropped together.
This concerns me,
You fitted the bearing into the housing,then the circlip,then the oil seal?
Even with housing,bearing and seal heated and the crown wheel chilled it should have been a bit tight,
I’ve Seen crownwheels that have had the main bearing spin on them and have been a loose fit like that.
Added to this heating the new bearing and seal to a high temp is not a good idea.
The crownwheel and housing assembly should also be rotated as they are pressed together to ensure the oil seal isn’t flipped inside out.
Hopefully all is well but it would be worth keeping a close eye on things for a bit
Edit also just reread your previous post,it sounds to me like it came apart too easily!
Keep a close check on play in the wheel,
It doesn’t read like it is a good tight interference fit into the bearing and hub
