I have noticed that my 83 G/S has a pronounced transmission whine. It occurs in the first four gears and goes when I pull the clutch in. It is particularly marked in low gears, at slow speed when on and off the throttle. Today I took it on a run and drained the transmission fluid. The magnetic sump plug had fine filings on the threads rather than the usual fluff. I also put the bike on centre stand and run the engine in gear with the rear wheel off the ground. I could hear a unhealthy churning noise that appeared to come from both the rear hub and the gearbox, this became the whine as I increased the throttle. I have taken a video and if you listen past the engine noise you should hear it. ( I am having trouble uploading this but will keep trying) The clutch engages fine, gears are selected without problem, so what could be wrong? The gearbox and final drive where rebuilt (before my ownership) by a specialist around three years ago, since then it has covered hardly any miles at all.
