Hi, I'm Having trouble selecting first gear, i.e., it's near impossible. I've been riding the bike relatively regularly, without any problems, gears changing without problem, finding neutral easy enough. Then suddenly first gear would not engage, not from neutral or second. All other gears are working perfectly.
The clutch is adjusted correctly. I've drained the oil, which looks clean, it wasn't very old anyway. There wasn't any pieces of metal on the magnetic drain plug.
I don't want to strip the gearbox down if it isn't necessary, the shimming and removing the flange and nut sound daunting. However I think that's going to be the only solution, unless anyone has any ideas.
