Looking for some guidance here on my first GSA.
The bike is a 2019 with 5000 miles and on the way home from the dealer I noticed a weird knock coming through the bike but mainly through the foot pegs, more the right hand side one I think.
There is no sound but is only felt through the pegs and happens when going over small road imperfections, sometimes cats eyes and mostly expansion joints and ripples in the road.
I haven’t had a chance to change different suspension settings to see if it makes a difference as was pissing it down on the way home and still trying to find out how stuff works.
Dosent seem to do it over larger bumps or speed bumps etc so that kind of ruled out the centre stand banging or moving.
Have scoured forums and some have said it’s a common fault and they all do it so looking for some feedback to see if anyone else has had something similar or whether I need to take it into dealer as it’s under auc warranty.
It’s quite annoying every time it happens as it’s hard to believe this is just something the bike should do, as it feels like a ball joint or bush failing, is a real mechanical metal on metal feeling through the footpeg.
Have grabbed the rear wheel and pulled at different positions to check for play in wheel/hub/ swing arm but seems fine.
Apologies if this has been covered already but just wanted some other experiences from you guys on here.
