Should be easy, disconnect fuel lines, breather pipes and electrical connectors.....undo/remove 4 mounting bolts (2 x side/underside + 2 at the back) and according to the manual...
"Raise the fuel tank at the rear slightly and remove it in a backwards direction."
Don't know what I'm doing wrong and/or if I'm just not getting the right technique but there appears to be no way the tank will come off!
See attached photos....forward part of the tank is wider than the mounting lugs on the frame that the tank fixes to, so no way it can be moved backwards nor raised enough to clear the mounting lugs??!!
WTF!
Left-hand side...
Right side....
WTF!
Left-hand side...
Right side....
