Fuel Tank Removal R1150 GSA Help
pnewman
BATH
Guys
After a bit of help , have removed the fuel tank on my R1150 GSA 2002 , I have removed all the quick connects and the vent hoses which come from the pump , in my usual stupidity i forgot to label these two, please see photos:blast , basically the ones in pict 1 on left connect to the two on the right picture , r they just vents to atmosphere ,
So now not sure which goes to which and if it matters
Also what is the best routing for the cross over hose the one with the white plastic connector
Any help appreciated
Now all i have to do is fit new battery , fuel filter , air filter , full oil change and trans and i am good to go. My first time doing all this.
Paul
One is a tank Vent The other one is a Fuel overflow (little hole at 9 o'clock under the filler cap Worth making sure this stays clear)
It doesn't matter which one as long as they are both clear, all they do is breathe or drain !
