re clutch / sidestand switchingThat is an idea I think I'm going to try! Thanks
Last night I thought I'd found the issue! The sidestand switch is defo buggered. But because I've been riding bikes forever, I just never leave the sidestand out, so never noticed it wasn't working. It'll need replacing. However with it disconnected, I'm still getting a big resistance reading across the battery leads (no battery fitted, alternator disconnected, starter disconnected...)
I'll get there! But all tips are welcome!![]()
if its a normal ABS2 bike (>=2007MY) - check the silly micro switch adjustment screw a) you aren't meant to fiddle with on the clutch lever for K bikes or b) the micro switch screw on the R series ones
I think mines is a smidge out (due to wear and tear) and sometimes it wont crank, then you do everything the same again and it will
see part 11
Clutch control assembly Diagram for BMW K25 (R 1200 GS) R 1200 GS 04 (0307,0317) (2007) Catalog | RealOEM.com
BMW parts K25 (R 1200 GS) R 1200 GS 04 (0307,0317) Clutch control assembly
