Part number for box just in case there are different versions.
Same part number as mine and confirmed as same dimensions . Only difference is I cut my front rubber bung down to 10mm height and yours is 14mm hence why your tool box is slightly raised at the front whereas mine is now parallel with the rear subframe top member
