1st gear problem on 1150GS
Proffesor Plumb
billericay essex
Hi can i ask, some times when i go to select 1st it will not move out of nutrual sometimes its fine,
i have had the clutch bleed, it also sometimes jolts in with a hammer noise any clues
steve.
steve.
normal, just let the clutch out slightly, whilst putting some pressure on the gear lever, its because at standstill, the shafts are not rotating.
These gearboxes take a little getting used to, within a couple of thousand miles your technique will have imperceptibly changed, they need a positive boot.
Stewart
