Hiya,
I have a 2012 Sertao with 6100 miles on the clock. As I have seen on these forums the G650 does have a somewhat agricultural gearbox between 1st and 2nd, so I have just made do however I have a problem now as I get this (last 500 miles or so in particular):
Symptoms:
At standstill, select 1st makes the usual clunk and bike makes a small lurch forward, its always done this however when I attempt to ride off its actually in neutral (although neutral light doesn't always light). Shift down again still clunks and may or may not actually be in gear. The only way I have been able to reliably engage 1st is to do above but leave my foot gently pressing down on the gear lever as I let the clutch out.
All other gears such as 2nd and upwards are as sweet as a nut.
What I have tried:
- Changed oil and filter as needed doing (about 1500 miles ago) used Castrol Power One 15W50 as per BMW dealership. I was hoping this might make the clunks better, but no difference.
- Adjusted clutch freeplay as Chaingangs FAQ on f650.co.uk http://faq.f650.com/FAQs/ClutchAdjustmentFAQ.htm . I have taken up pretty much all cable slack so that the friction zone is almost all the way out on the lever to get maximum clutch disengagement (this helped a little). One thing I have noticed is that Chaingangs FAQ clutch lever (gearbox end) dimension A is 47-52mm however mine has a dimension of 43mm with the clutch lever all the way out i.e would be smaller if I pulled the clutch lever in to the Release Point. Does the G650GS have a different A dimension to the F650's?
If I moved the clutch lever (gearbox end) above one spline outwards then there is not enough slack in my cable to get any free play at the hand lever end even with the adjuster all the way in.
Any ideas as its somewhat of a danger as unless I have my foot resting down on the gear lever when I start off then I ain't going anywhere.
Thanks in advance.
Symptoms:
What I have tried:
Thanks in advance.
