2.5mm to 3.5mm conversion lead for earpiece
Dave56
Yaxley, Peterborough
Does anyone know where I can purchase a 2.5mm to 3.5mm conversion lead for the earpiece/headphones for the 2610, which is at least a metre long.
How about buying a 2.5mm/3.5mm adapter or something like this?
http://www.amazon.co.uk/3-5mm-AUDIO-HEADPHONE-ADAPTOR-BLACK/dp/B000VLLI18
Cheers Paul, if it had a longer lead that would be spot on. I have one like this at present but when I connect to the earphones the lead blows about all over the place when in use. If I can get a longer conversion lead I can then pass this under the tank bag base, the lead on my current earpieces is`nt long enough to do this at present. Hope this makes sense.
I've got the bits you need . A 2.5 male minijack to 3.5 male minijack on a lead about a metre long. Both jacks are riht angle so take up less romm. Yours for the princly sum of £5, delivered.
Thanks Spikehammer, I`ll take them. If you PM me your address I`ll stick a cheque in the post along with my address for you.
