nakednut
Good Morning All:
I'm a newbie here and I have a few questions concerning my 2000 R1150GS (US Model)...Here's the story: I purchased the bike a few weeks back for $1,800.00. It was a one owner bike with 8K original miles. It was in the previous owners garage next to his snow blower which caught fire. The bike was damaged on the front left side. Melted the ABS lines, the lower front wheel mudguard, the alternator cover, the alternator belt, the oil pressure wire, and the tire. The fire was put out within 5 minutes, so the no other wiring was affected. Also, there was some discoloration on the left side cylinder and valve cover. I first drained the oil then removed all the melted parts. Next, I removed the gas tank to inspect for any further fire damage, which there was none. I also replaced the battery. I installed a new belt yesterday and filled her with oil to see if I could get it to start. Well, guess what, no spark....now, here's my question, if the wire that is connected to the oil pressure sensor is disconnected will it stop the bike from running? I tried grounding the wire, but still nothing. What that did was make the oil light come on when the key is turned. I am waiting for the new oil pressure sensor to come in the mail, and I hope that does it. If not, I have a feeling it's going to be the Hall/Ignition sensor. What do you guys think? Anything else that it could be before I spend $250.00 for the Hall sensor..
Thanks,
Craig
PS: This is an awesome site...lot's of information....
Thanks,
Craig
