Hi all, I'm a new boy to this, a complete spudoofer if you like, so any advice most welcome! I've got a 2003 1150 gsa 62000 on the clock, bought it to fuel desire to ride a gs, it is a bit tatty to say the least but it goes, when I can get it started !
Had it for less than a year and have just started going out on it really. Gave it an oil and filter change and have had intermittent starting issues with it and put new battery on it last week, as I thought that could be part of the problem. Since discovered, that isn't the issue. I've noticed the following;
Battery is new and charged up and just about fires the engine, laboured starting as if not enough power to turn the engine.Too many attempts (more than 3 will drain the battery) so have to jump start. Done voltage check all good with the battery.
When revving engine, lights get brighter so alternator appears ok and charges battery.
Just back from a short trip through Wales (nightmare, mountains, no phone signal!) After riding a good few hours turned off the engine then had nothing, overheating maybe, sticky starter?? Had to bump start it, luckily was on the right side of a mountain!
Does it need a new starter and is there any fault finding I can do to suss this out?
Next issues!
Gear indicator hit and miss, often doesn't show correct gear.
Neutral light often doesn't light up when riding or stationary when in neutral.
Have fuel pump initiator noise when switching kill over to start, but I've now noticed what I think is fuel pump noise when engine is running. Could be I haven't noticed it before or it is now louder for some reason? Fuel pump ??
So that's about it until the next thing goes wrong.
Any help most appreciated
Cheers all
Next issues!
Cheers all
