2005 gs startup battery light
eballard
Member
Swindon
Hi all just got a 05 gs and have a question regarding the startup lights.
It does the normal startup but when I start the bike the battery and red triangle appear for a second then disappears, seems to start fine no issues turning over (so far). Is this normal or is this a sign of the battery on its way out?
On a side note bike seems to run well :)
Hi ,will give it a go and see what happens not sure on age will have a check tomorrow. Just wondering if it normal before I go back to the dealer or not.
Once running just blip the throttle its just getting up to speed and overcoming resistance etc and will settle to charge pretty quick
Thanks all,
I'll see how she goes. I have noticed a bit of a clunk when pulling in and releasing the clutch but the gearbox seems ok and the bike is smooth running for a twin. I'll have to have a check of the play in the FD I think.
Does anyone know a good independent bmw dealer around the Swindon/Newbury area? Needs an annual service and FD oil change I believe.
Fit a voltmeter under £10 for an LED type. Easy to fit & will show you how well the battery holds up under different conditions.
Sent using techie stuff
