2005 R1200RT Indicator Issue
Gerbil007
Member
Chippenham, England
Evening all. Bit of an odd one this, so just testing the water to see if anyone else has experienced the same issue. My indicators seem to have developed a mind of their own. The left indicator will randomly decide to come on and wont cancel without a long press of the cancel switch, plus pressing the left indicator switch. If I try to indicate right when this occurs, both indicators operate simultaneously, as if the hazards are on. In addition, if I indicate right, it will self cancel after a short period. WTF is going on? I'm assuming water ingress somewhere, but I dont even know where to begin. :nenau
Likely to be a failed switch.
The indicator lever pushes down on a micro switch, which you can replace if you can solder (though it is fiddly).
I've done a few. You'll need to search for a switch like the below. I got mine from America, but I believe either motorworks or motorbins started selling them.
