Hi all im going to look at a 2008 mk2 1200 gs with 38000 miles with full service history,is there anything i should be looking for engine ways with the miles down the line ?
Check the ABS tell tale light lights up and then goes out as you pull off ( within 100 meters of movement)
Put it on the centre stand, and hold the rear wheel at 12 & 6 oclock push the wheel away and toward you there should be no play do the same at 9 & 3 push and pull the wheel away & toward you
again no play -
this is where its tricky, bmw say a little bit of play is acceptable... but i'd go with the concencus no play is acceptable - if there is any play factor in a hub rebuild (mikeyboy is the man to go to)
Service history - If it's all main dealer, then you laughing - indy & home serviced, take with a pinch of salt, it may well have been done perfectly correctly, but a stamp can be obtained anywhere
Looke at the oil filter, it should be Mahle branded, if int any other make tick the caution flag
check what oil was used in the service, you can use fully synthetic, but i believe the norm is 10-40 20-40(50) Mineral oil
There not the quietest of bikes, but there should be no untoward clattering, you will get injector & some valve timing noise.
then i'd say overall conditon & extras ( vario pannier set, crash bars, aux lights etc )
