Diamshill
Hi all, I am relatively new here and have an issue with starting my 2009 1200GS (K25). I commute on the bike daily and this morning I stopped to refuel; after filling up, the bike turned over but failed to start. Pressing the starter button a second time didn't do anything; no starter motor activity, no dimming or flickering of the dash display, no clicking of the starter motor. Pressing the starter button now only gives a single click somewhere near the front of the bike but I can't pinpoint where exactly. Bike is showing green neutral light, on centre stand with side stand up, same symptoms with clutch pulled in. If the starter relay is underneath the seat then its not that. I have replaced the battery in the key fob, disconnected the bike battery for about 15 minutes, tried a jump power pack, all to no avail. There are no error messages on the display either.
I started pushing the bike home and actually managed to jump start it going downhill, so I think this suggests it isn't a key fob or immobiliser issue.
At home I ran GS-911 diagnostics & tests; I'll post reports tomorrow as I need to re-run the diagnostics and save the files...
The GS-911 initiated the fuel pump, also didn't show any issues with the gear selections, clutch or side stand switches.
I do have an EZ-CAN fitted, though diagnostics didn't show any issues with it. The same problem is present with the EZ-CAN disconnected.
Clutch hydraulics were recently bled, however the clutch issue of not always disengaging doesn't appear to have been resolved.
Starter relay (found underneath the ECU under the tank) & battery replaced.
I searched through starting issues on this forum but couldn't find anything matching these symptoms. A similar post was from Michaelwhy found here, though there are similarities, this one hasn't been modified in any way. Also, testing the starter button via the relay is not possible given its accessibility.
I'm heading for the start button now, but unsure how to test it.
Any help or pointers would be greatly appreciated. Many thanks
Reading your symptoms, As you say you have a neutral light and the pump primes, then the bike thinks it’s in neutral, so my money would be on either the button or the starter relay.
The relay clicking when you operate the kill switch sounds like the motronic relay.
Pulling the clutch in would only work if the clutch microswitch was serviceable.
Putting your finger on the starter relay when you press the start button should tell you if the relay is being powered or not
You can test for the button power at the relay. You can also jump across the relay contacts.
I posted how to check the...
