CandyMan_ZA
Calling all the gurus out there.
I have a most peculiar behavior on my 2009 R1200GS Adventure. My ABS deactivates randomly. When this happens initially it was only the front ABS, the rear wheel still had ABS. But since last weekend it is now deactivating on both front and rear wheels. The ABS warning light comes on. Other symptoms are the indicators no longer self cancel as well as the moment the ABS cancels and the light comes on the engine does a split second misfire, this is not always noticeable but it happens.
I have pulled and prodded all the wires and cables under the handlebars while riding in the hopes it was something loose or shorting out.
I have managed to replicate it. In the video below you can see (albeit a bit shaky) that the ABS light comes on. I pulled away in first gear, all normal, then with a quick twist of the throttle, not enough to wheelie or even unlikely to cause the Traction Control to kick in, the warning light comes on. I did the same thing again in second gear. This can be repeated in succession with 100% reliability.
I have checked the battery terminals, nothing is loose.
I have been to my BMW dealer where they extracted the error codes, there are ABS voltage and speed sensor warnings present. It is booked in for Thursday but I fear the worst, the dreaded ABS booster pump
https://youtu.be/pV1OcZFVcPg
Any suggestions?
Kevin
Any suggestions?
Kevin
but alas after cleaning it the symptoms are the same.
