2010 1200 GS starter relay location
mario.costasa
St Albans
I am trying to locate the new position of the starter relay on my 2010 1200Gs to help with an intermittent start issue
I have replace the handlebar switch but now replacing the relay as only £15 before I attack the starter
I know it isn't around the under seat tool tray area and have now stripped the bike back to the look under the ZF unit / ecu under the tank
The replacement sent by motowerks is pretty small and without taking apart further can someone point me in the right direction as I feel like I am looking for a needle in a haystack
I even had to resort to riding the Honda CRF in today!!
Mario
Mario
i think its in the plastic holder by the zfe,next to the fog lamp relay.
Just for your info, I've just had to have my 2010 R1200GSA into the dealers for an intermittent starting issue. Started OK from cold but if the engine was warm, 50% of the time I'd have to give the starter motor a tap with my heel to get it to spring into life. The starter motor was changed but the problem persisted so this time they dug a bit deeper and found that it was down to corrosion in the power cable to the starter motor. Changed the cable, no more problem!
