FRONT HEADLIGHT REMOVAL:
Remove screen ( 1 screw )
Remove the dark see- through plastic shrouds. If you struggle with this, sop now.
Remove the 2 top screws holding this in place and the 2 underneath the light.
This grey panel pops out each side - I used a fairly small screwdriver between plastic and metal taking care not to scratch the metal coating.
Remove the dash fixings and disconnect the plug if desired and store away from bike.
There are then 4 headlight screws that go in sideways into the light. Remove.
The plastic should prise apart thus and if it doesn't you won't get the light out....be patient:
Carefully pull out the light and remove connector, store in a safe place.
You're left with this:
What I was looking for was the two pairs of wires for accessories:
This pair is permanent live:
Cont'd....
