Tannemann...Of course a rev limiter cuts ingnition/fuel off to prevent the engine from damage through over-rev...But if he bikes makes peak power at 10000 rpm and at 10100 or so it shuts off it is useless on the track and you have to short shift at probably 9500 not to run into the limiter...
You don't really rev an engine to the rev limiter as this will slow you down when you are trying to measure performance ie acceleration, lap times etc... . You shift gear at about peak power so that the revs fall back to above the torque curve in the rev range to start building up to peak power, ie chasing acceleration you need revs. Each engine design will have different personalities if I can call it that and has to be used how it performs best. So iaw if you hit the rev limiter trying to go fast it is rider error unless you managed to spin the rear up and that is where the soft limiter saves the engine, not you.
