640 adv,time for some tlc
Magnon, the 625 xfc silencer fits straight on and can be modified to further open it up.
Mine had one when I first got the bike.
Thanks very muchly for that piece of information, I'll follow that up.
uh-hum
If anyone is looking to off-load such item I'm now in the market?
Top man, done and dusted...:beer: Owe you one............:augie
You're welcome mate :)
I'm just doing some weight reduction on my newly acquired 640 Enduro
Right chaps!
What hid or led set up have you managed to fit in the dip beam projector lamp?
I bought some 40 watt led bulbs,there isn't room at the back on the dip lamp,as the brake pipe wants to rip the fan of the back:P
I have a les wassell h1 hid unit but the glass part of the burner is too large to install.,
Share some knowledge :thumb
Why not keep lights original and add some LED DRL's or a similar set up to your 1200 using LEDs, just to give you a boost of light if you need it?
You little tinker!!!!!!
You spend too much time on these forums, your stealing all the parts:eek:
It's called wifi Mike and I have it at work, it compliments my iPhone perfectly, do you know what I speak of? :augie
B
Right chaps!
I forget which mine are but dip and main are both HID running through relays.
I also wired it so dip stays on with main, it was easiest to trigger the dip relay from the side light that way it stays on when you hit main :)
Three days of fucking about:D
I felt the original KTM fuel valve was exposed and vulnerable to damaging the expensive fuel tank if it got taffled up with some passing object, so made this alloy replacement to use with an inline fuel tap which I think it's a better option even though there no longer a dedicated reserve facility, but the right hand side isolation valve can always be closed off to keep some fuel in reserve:thumb
Sorry Mike only made the one but ................... :aidan
Hmmmmm just the one!
Best not come to me if you run out of fuel.
And get the workshop tidied up:rob
Prototype on my bike, nothing but the best for yours........... Sir!
I have got you a new fuel valve gasket on route to my place:thumb
