R1150GS , bikes runs fine, no problems or creaks, normal services done by myself. Question, while I have the bike up on the ramp is there anything additional that I should be checking for or do considering its mileage.
Check your clutch slave cyl pipe hasn't corroded. Change clutch fluid.
Lube gear linkage.
You may expect probs with the front loom from the ign switch before too long.
Rear paralever bearings could need attention, but just check for any play first.
Then ride it for another 67,000 miles
