I’ve decided my GS’ing days are now behind me so it’s time to sell the GSA and everything else I’ve accumulated over the years. First up for sale is my bike, reg RO08 VNK. I bought this off the site in 2009 when just under a year old if I remember correctly - it had a couple of thousand miles on the clock so I am the second owner. It’s been garaged since day one.
The first few services were completed at Bahnstormers in Alton until the bike was out of warranty, from there on in, I have completed all the required servicing work myself, as I’ve done with all my bikes since 1978. I invested in all the necessary tools, a GS911 and the K25 service manual. I have detailed and recorded each of the mileage based services on the correct checklists as I did them but as you can see from the mot history, there’s not been much mileage added over the last few years. So in addition to the mileage related service work, I have also changed the oil and filter annually plus bled the brakes every two years including the ABS pump. Clutch fluid has also recently been changed. There are no oil or fluid leaks anywhere.
Under warranty, Bahnstormers replaced the screen due to cracking and the final drive main bearing was replaced under goodwill. The final drive was completely rebuilt in August 2023 as the shaft seal was leaking so it was sent off to Overland and Classic for a complete overhaul with new bearings all round.
I replaced the ESA suspension with Wilbur’s WESA front and rear at around 19k miles when the BMW shocks gave up the ghost- the rear spring is rated for a 100kg rider with full luggage. These are superb!
The only long running saga has been with the fuel strip sensor. I had three of these replaced but they all eventually failed. Glad to find an improved version was available via Motorworks 18 months ago so fitted one of those and it’s been all good since then.
Everything on the bike works! ESA, alarm, ABS, tyre pressure sensors, fuel strip, onboard computer etc, etc. Engine runs great and was remapped at Hilltop a long time ago…..
There is only one issue of note the new buyer should be aware of. There is a slight current drain off the battery which I think is the ECU not completely shutting down on power down. If not riding the bike for a few days I recommend using a trickle charger or simply disconnecting the battery negative lead. I will throw in the Optimate IIISP I use with the sale.
Moving on from my ramblings this is the list of what’s included in the sale:
Two keys plus wallet emergency key
Mileage is 46866. Mot’d till June 2027. Reg: RO08 VNK
Wilbur’s WESA front & rear electronic suspension.
Enduro gearbox
ESA, ASC, onboard computer
Tyre Pressure Monitors
Alarm with 2 x remote fobs
Mudsling
Front and rear fender extenders
Cymark SS front crud catcher
Front fork and stanchion protection
Front and final drive crash bungs
Locking toolbox (2 keys) with slime compressor, puncture kit, tools etc
Zumo 660 satnav with lifetime maps
BMW (keyed to bike) Aluminium panniers (one with 12v power) with inner pannier bags, carry handles and stainless steel interconnecting table. External fuel and bottle racks with ties. 2l fuel bottle.
Givi 52l top box (takes 2 x full face helmets) x 2 keys
Fuse box (30amp) with 2 x unswitched and 6 switched outputs. SAE Power lead for pannier, compressor etc
DIN plug connected to unswitched 12v supply to power compressor etc. and original socket still connected and stowed in cubby hole under fuse box.
Grip puppies
Sidestand enlarger
Gear shift enlarger
Frame protectors
New and improved fuel strip sensor
Oxford bike chain x 2 keys
Optimate IIISP charger
Full tank of fuel
Bike is available to view in Devizes. I can also send a video of the GS911 real-time outputs with the engine running if anyone wishes to see that. The above configuration is what’s on sale with the bike. I do have other items that will be up for grabs after the bike is sold but I won’t list them here as I will give the new owner first refusal.
Price is £3,750 ono
Thanks for looking and getting to the end of the ad….
Enduro gearbox
Mudsling
Grip puppies
Sidestand enlarger
Gear shift enlarger
Frame protectors
Full tank of fuel
Price is £3,750 ono
